Configures an external filter policy.
| area_identifier | Specifies the OSPFv3 target area. |
| policy_map | Specifies a policy. |
| none | Specifies not to apply an external filter (removes the existing policy, if any). |
N/A.
For switches configured to support multiple OSPFv3 areas (an ABR function), a policy can be applied to an OSPFv3 area that filters a set of OSPFv3 external routes from being advertised into that area, in other words, filtering some of the inbound AS-external-LSAs.
OPSFv3 routers that do not have enough memory to hold the entire AS-external-LSAa should configure an external area filter to drop part of the external-LSAs. Configuring this policy will enable routers with limited resources to be put into an OSPFv3 network.
Using the none mode specifies that no external filter is applied.
Any other policy attribute will not be recognized and will be ignored.
The following is an example of an external filter policy file:
entry one {
if match any{
nlri 2001:db8:3e5c::/48;
nlri 2001:db8:2146:2341::/64;
} then {
deny;
The following command configures an external filter policy, nosales for area 1.2.3.4:
configure ospfv3 area 1.2.3.4 external-filter nosales
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
